430
OnUploadFinished doesn't work
I'm trying to get the filename after upload it and put the path in a label using csharp, I used the OnUploadFinished method but it doesn't work.
You find below the code that I used.
            <asp:Label ID="lblfinished" runat="server"></asp:Label>
            <ig:WebUpload ID="webUpload1" runat="server"
                OnUploadFinished="webUpload1_OnUploadFinished"
                MaxSimultaneousFilesUploads="1" Mode="Multiple">
                    <ClientEvents FileSelecting="fileSelecting" FileSelected="fileSelected"
                        FileUploading="fileUploading" FileUploaded="fileUploaded"
                        FileUploadAborted="fileUploadAborted" CancelAllClicked="cancelAllClicked"
                        OnError="onError"/>
            </ig:WebUpload>
CSharp
    protected void webUpload1_OnUploadFinished(object sender, UploadFinishedEventArgs e)
        string filePath = String.Format("{0}{1}", e.FolderPath, e.FileName);
        lblfinished.Text = "Name: " + filePath;
The code works correctly, only the method doesn't work.
Thank you
