I got a problem here, and explain it in the screenshot. :)
Hi Graham,
I've read that before, but because I get the data provided by our client, and the data is in a mass, so I wonder if there are some other ways to deal with the style with some properties.
It seems that I forget to replay your answer, ahhhhh, feel so sorry.
Hi Lazar,
Thanks for your reply, I think I should do something to my data. :)
Did you see my answer here?
http://community.infragistics.com/forums/p/63334/321141.aspx#321141
-Graham
Hi asgardsinc
In principle, you can do what you want with the axes.minimumValue & axes.maximumValue options for the category axis. These options are of number type so this will work for you if the category series for your chart is of numeric type. If it is of a date type you will need to apply the solution you obviously found for yourselft - put empty records with null values in the beginning and at the end of your data.
Please, answer if you need some more information.
Now understand better what you want to achieve. I'll do a short research and post an advice for you.
