285
Iggrid selection and delete event firing at the same time
I am using the iggrid to show some data. Now I have the requirement where on Grid Row selection details view opens up also if I hover over the row, the delete button should appear [standard delete functionality as provided by iggrid]. I am using jquery widgets for both the summary and details view.
Now, the problem is - Whenever I click the delete button, the selection changed event gets fired and the navigation moves to the details view. Is there any way, I can stop firing the selection changed event whenever the delete event is raised ?
I am pasting the code that I am using in this context :
 gridElement.igGrid({
                autoGenerateColumns: false,
                dataSource: igDs,
                autoAdjustHeight: false,
                columns: [
                    { headerText: "Login Name", key: "LoginName", dataType: "string" },
{ headerText:"First Name", key: "FirstName", dataType: "string" },
{ headerText: "Last Name", key: "LastName", dataType: "string" }
                features: [{
                    type: "local"
                      mode: 'row',
                      mouseDragSelect: true,
                      activeRowChanging: function (e, args) {
                          //alert("Selection changed");
                          var username = args.row.element[0].cells[0].textContent;
                          var state = $.bbq.getState() || {};
                          state.layout = "userdetail";
                          state.username = username;
                          $.bbq.pushState(state, 2);
                      enableAddRow: false,
                      editMode: 'none',
                      enableDeleteRow: true,
                      // event raised before row was deleted
                      rowDeleting: function (e, args) {
                          var username = args.element[0].cells[0].textContent;
                          var confirmmsg = confirm("Do you want to delete user :" + username);
                          if (confirmmsg) {
                              //                          that.options.sendRequest({
                              //                                  url: "/UserAdmin/DeleteUser/username" + username,
                              //                                  success: function (data) {
                              //                                      alert(data);
                          return false;
