Is there any event to capture the row double click event? And i need how to read an item in the selected row and pass it as a query string to some other page. I need sample in ASP.NET MVC Razor (cshtml). It will be great if some one can assist me on the same.
Is there any updates on this?
Suresh A
I have added the solution file to the support ticket. Kindly check the same and let me know ASAP.
Hello Suresh,
Thank you for getting back to me.
I have created a support ticket with case number CAS-82287-FDBWKR,
which you can monitor by going to the “My IG” tab on our website, and selecting "My Support Activity" from the drop-down.
https://ko.infragistics.com/Membership/MySupport.aspx
You can attach your code in a zipped format to the case.
Let me know if you need further assistance
Hi Tsvetelina Georgieva
Where can i submit the code? Can you please share me the path to upload the solution so that i can do the same. Because i tried searching for the incident number which you have mentioned i was not able to find any.
Thank you for your update.
I am not able to
Can you please upload an isolated sample reproducing the issue?
You can do this here or through your support ticket CAS-82287-FDBWKR
Hope hearing from you
