I'm using NA 2011.2 (with sr), C#, Razor, jquery 1.6.2
I Just wanted to point out something that might be a minor bug with the igGrid.
If you are viewing your web page in a stretched out browser, such as when maximized, and then adjust the size of the browser to be small enough that you think scroll bars should appear, they do not.
If, however, you then refresh the page, the horizontal scroll bar shows up as expected and behaves as expected. At this point if you resize the browser large enough the scrollbar goes away, and if you shrink it back up, it re-appears as expected.
It's only an issue if the page is first rendered in a large enough browser that the initial state is without a horizontal scrollbar.
Hopefully that was clear and made sense.
Thanks!Tony
Hi Matias,To my current reply I've attached the sample Tsvetelina used for the bug she submitted - can you please try reproducing the problem you are experiencing in it?Also, if you can attach a couple of screenshot of when the issue is occurring, that would be awesome and extremely helpful.PS: @Anthony, thanks for supplying the bug/development issue number Cheers,Borislav
Tsvetelina,
I´m having the same problem and it’s not related to the grid width or high.
When in compatibility mode the grid only shows the vertical scroll and not the horizontal scroll.
If I remove the vertical scroll by letting the grid grow for all rows height or by enabling paging and having the page rows fit in the grid height then the horizontal scroll bar appears.
It seems I can have one but not both working.
Matias
A case was opened and I got a response this morning indicating that:
Development Issue #100187 to be released soon
Hopefully we'll see it fixed soon.
is there an update to this post?
Hello Tony,
Thank you for sharing the width configuration.
I was able to reproduce the behavior only when width=100%
I also created a support ticket on your behalf CAS-82032-DLMDNM
and will keep you updated regarding the progress of the issue.
