I have three questions regarding the jQuery tree. I am using MVC3 and razor.
I have set up the tree using code in the controller:
TreeModel treeModel1 = new TreeModel();treeModel1.ID = "TreeInController1";// Configure data sourcetreeModel1.DataSource = col1;
// Configure specific display and interraction propertiestreeModel1.LoadOnDemand = true;treeModel1.DataSourceUrl = Url.Action("TreeGetData");treeModel1.CheckboxMode = CheckboxMode.TriState;treeModel1.SingleBranchExpand = true;treeModel1.ParentNodeImageUrl = "Computer.png";treeModel1.LeafNodeImageUrl = "Computer.png";
// Define bindingstreeModel1.Bindings = new TreeBindings();treeModel1.Bindings.TextKey = "Name";treeModel1.Bindings.PrimaryKey = "StateId";treeModel1.Bindings.ValueKey = "StateId";//treeModel1.Bindings.ImageUrlKey = "ImageUrl";treeModel1.Bindings.ChildDataProperty = "Courts";
1) How do you set the child leaves Bindings using code in the controller?
2) How do you change the icon of a distinct leaf item using code in the controller?
3) How do you return the selected items to the controller?
Hi Jadem,
Could please brief on how to pass the selected nodes list to controller. About Controller Method and Java Script funct. It will be greatly helpful to me.
Thank you.
Hi there,
The checkedNodes method returns a javascript array of node objects. The node objects themselves look like this:
[{path: 'Path_string', element: jQuery_Object, data: Object, binding: Object}]
You don't need to transmit the entire object. If you want to send the node to the server using a specific key to recognize it, then the path string would suffice (node_array[index].path). If you need specific data member to recognize the node, which is a more common scenario, then you extract it from the data object (node_array[index].data.dataMemberKey) and send that to the server. The binding object holds the bindings defined for the specific level of the tree, while the jQuery element is used to reference the node's corresponding DOM element and its children from client code.
I hope this explanation clears it for you somewhat. Feel free to ask if there is anything else unclear and thank you for using the forums!
Normal 0 false false false EN-US X-NONE X-NONE
I just:
var nodes = $("#Tree1").igTree("checkedNodes");
Tree1: JSON.stringify(nodes),
I had to Jsonfy the array so I wouldn’t get an error passing it to the controller.
The infragistics notes only say “returns an array”. I was hoping it was a Infragistics class so I wouldn’t need to create a custom class.
Hi again,
In terms of Javascript this is just an object. You can define a serializable object in your model/controller which maps the properties of the javascript object that you're having. Also did you extract this from the selected node or is this some custom object that you have created?
Looking forward to your reply!
I figured it out.
Btw, what type of object is this?
name "[{\"path\":\"1_5100\",\"element\":{\"0\":{},\"context\":{},\"length\":1},\"data\":{\"Name\":\"San Diego\",\"CityId\":5100},\"binding\":{\"textKey\":\"Name\",\"primaryKey\":\"CityId\",\"valueKey\":\"CityId\"}},{\"path\":\"1_5101\",\"element\":{\"0\":{},\"context\":{},\"length\":1},\"data\":{\"Name\":\"Sacramento\",\"CityId\":5101},\"binding\":{\"textKey\":\"Name\",\"primaryKey\":\"CityId\",\"valueKey\":\"CityId\"}}]" string
