420
link in a column
Hi ,
I would like to add a column in the grid which has a hyperlink. This link when clicked should use the primary key to display another page in the pop-up. It would be really helpful if the pop-up could be done using the iframes concept.
The grid is in a webform and doesnot have a row template and is not using Razor or MVC.
  • 24671
    Verified Answer
    you can't have a templated column (i.e. links inside cells) without defining a rowTemplate. You can refer to the following examples:
    http://samples.infragistics.com/jquery/grid/row-template
    Hope it helps. Regarding the pop-up and the rest of the UI - i think this is more application specific and i don't have enough details to suggest any specific solutions. But you can always attach a click handler on the links (either directly in the template, or with a jQuery selector, once the grid has been rendered - and open your popup from that handler). Thanks,
    Angel
