765
IgGrid with hidding feature select columns in client side in cicle
Hello
I have my iggrid in MVC3, I'm using version 2011.2, I wonder if it is possible to use the feature Hidding, I can hide all the columns, and make a loop to display only the columns that are needed.
I want to do client side, it will be possible to do this.
regards
Thanks in advance.
  • 24671
    hey,
    i think it's better to just define the columns you would like to show . Is there any reason you'd like to do the opposite?
    It's possible via the hiding API (yep you can use the hiding since it's a 11.2 feature)
    https://www.igniteui.com/grid/column-hiding
    you can iterate through the columns and get their keys in the following way:
    var cols = $("#grid").igGrid("option", "columns");
    for (i = 0; i < cols.length; i++) {
        var key = cols[i].key;
       $("#grid").igGrid("hideColumn", key);
    Hope it helps. Thanks
    Angel
