175
Binding Feeds Atom file (produced from RDL report) to HTML 5 chart
I have generated .atom file using Export to Data Feeds  option provided by SQL Reporting Services 2008 R2 RDL report. Report is hosting a chart. Now I want to load this feeds OData i.e. .atom file (which is in XML format) into HTML 5 Infragistic chart control.
I downloaded jquery samples (NetAdvantage_jQuery_20112_WithSamplesAndHelp). I can see chart example which bind to the OData but it’s in JSON format not XML.
Following is the sample Atom file which I am trying to bind to HTML chart:
Do we have any samples which supports OData binding but with XML format not JSON?
Any feedback or help will be appreciated. Thanks.
