180
Add column Using API
I want to add a column to ig grid using API.
I have a button in page if user click this button I want to add a new column to the grid. How can I do this. below is the code please see  $("#btnAdd").click(function ()
var products = [
            { "ProductID": 1, "Name": "Adjustable Race", "ProductNumber": "AR-5381" },
            { "ProductID": 2, "Name": "Bearing Ball", "ProductNumber": "BA-8327" },
            { "ProductID": 3, "Name": "BB Ball Bearing", "ProductNumber": "BE-2349" },
            { "ProductID": 4, "Name": "Headset Ball Bearings", "ProductNumber": "BE-2908" },
            { "ProductID": 316, "Name": "Blade", "ProductNumber": "BL-2036" },
            { "ProductID": 317, "Name": "LL Crankarm", "ProductNumber": "CA-5965" },
            { "ProductID": 318, "Name": "ML Crankarm", "ProductNumber": "CA-6738" },
            { "ProductID": 319, "Name": "HL Crankarm", "ProductNumber": "CA-7457" },
            { "ProductID": 320, "Name": "Chainring Bolts", "ProductNumber": "CB-2903" }
        var adventureWorks;
        $(function () {
            $("#btnAdd").click(function () {
//Here I want to add a column to grid
            $("#grid1").igGrid({
                autoGenerateColumns: false,
                columns: [
{ headerText: "Product ID", key: "ProductID", dataType: "number" },
{ headerText: "Product Name", key: "Name", dataType: "string" },
{ headerText: "Product Number", key: "ProductNumber", dataType: "string" },
{ headerText: "Color", key: "Color", dataType: "string" },
{ headerText: "Safety Level", key: "SafetyStockLevel", dataType: "string" },
{ headerText: "Reorder Point", key: "ReorderPoint", dataType: "number" },
{ headerText: "List Price", key: "ListPrice", dataType: "number" },
{ headerText: "Standard Cost", key: "StandardCost", dataType: "number" },
                dataSource: products,
                responseDataKey: 'd.results',
                features: [
   type: "local"
                    type: "remote",
                    pageSize: 12
                    columnHidden: function (ui, args) {
                        var Columns = localStorage.getItem('Columns');
                        if (Columns === null) {
                            Columns = args.columnKey + ";";
                            localStorage.setItem('Columns', Columns);
                        else if (Columns.indexOf(args.columnKey) < 0) {
                            Columns += args.columnKey + ";";
                    columnShown: function (ui, args) {
                        if ((Columns != null) || (Columns.indexOf(args.columnKey) > 0)) {
                            Columns = Columns.replace(args.columnKey + ";", "");
                    columnSettings: [
                                    { columnKey: "FirstName", allowHiding: true }
                    deferredResizing: false,
                    allowDoubleClickToResize: true,
                    columnSettings: [
                                        { columnKey: "ProductID", allowResizing: true },
                                        { columnKey: "Name", minimumWidth: 40 }
</script>
<body>
<a href="BLOCKED SCRIPTvoid(0)" id="btnAdd">Add Column</a>
    <br>
    <table id="grid1">
    </table>
</body>
