Just wasted many hours trying to understand why code which works perfectly on my machine, fails on someone elses.....
I have a screen with an iGrid....
Getting the following error :
Microsoft JScript runtime error: The remote request to fetch data has failed: (parsererror) 'JSON' is undefined
Turns out its a 'compatibility mode' problem. When enabled/disabled (icon is blue on IE9) the script barfs, when grey it runs just fine.
As my system will be used by users with different browsers. OS's etc. (well thats WHY I am using your jQuery components in the first place :-O), I need to know that their systems will work without my having to tell them to use 'compatibility mode (or not).
If we are missing a JSON parser - then why not just supply one with the website ???. Surely we must be able to point at a suitable parser ???.
NB As I am still trialling your software I only have the minimised js files available so debugging exactly what went wrong is difficult to say the least!!
Graham
Thank you for the Json2.js file...that was a life saver!!!!
Your solution worked for me..
My ie8 have the same problem,
Use this method did not solve, I use is 2012.1 infragistics. Js
Angel,
Might be simpler if I just point you (privately!) at our site - its still only demo.
Obviously I don't want to include the URL here in public.....
You can get my email from my login ??.
Hi Graham,
could you provide me some more info about the issues related to layout? Some screenshot or a list of errors (if any) would really help. Thanks !
Angel
