First, sorry if this is not the right forum for this. If it is not, would someone kindly direct me to the correct place to report bugs?
IE8 & Firefox: The "Show N Records" and "Pg N of M" select boxes appear "behind" the other HTML elements when they popup.
Already reported? Is there a known fix?
Robert
Excellent! :)Let us know if you need help with anything else.
Cheers,Borislav
I have fixed that problem.
Hi Robert,
This is most strange indeed.We've tested the Paging feature extensively so there shouldn't be a problem in such a generic scenario.
Can you please provide me with some details on the questions below so I can help you with this:1. Can you provide us with a small sample page in which you are able to reproduce the problem?
2. What build are you using?
Looking forward to your reply.
Cheers,
Bobby
PS: If you've found a bug, generally, I'd suggest you use the support contact form at http://ko.infragistics.com/support/submitrequest.aspx
