290
Error in framework when appending partial view to div
I'm using igGrid with MVC2, building a GridModel as a property of my ViewModel and then returning a partial view through JQuery $.get. On success I call:
$("#myDiv").append(partialView);
This throws an error in ig.ui.grid.framework.min.js at the following lines:
$("#"+id+"_displayContainer").parent()[0].addEventListener("touchstart",$.proxy(touchstart,this),false);
and
$("#"+id+"_displayContainer").parent()[0].addEventListener("touchend",$.proxy(touchend,this),false);
The error is: Microsoft JScript runtime error: Object doesn't support this property or method
Any assistance you could offer in resolving this error would be appreciated
  • 24671
    Suggested Answer
    are you using IE8 to view the page? i think this is unrelated to partial views and MVC, as far as i remember this was a known issue which was a regression, and was subsequently fixed, so i would suggest to get the latest service release and check it out - the issue should be gone.
    hope it helps. thanks
    Angel
