I got two default groupby columns.
When I set the InitialExpand(false); the first column unExpand as expect.
But the second column did unExpand as expect. Seems the click on the Expand button will unExpand the all sub nodes. It's not I want, I want the first level child unExpand but other keep the status as original.
Does Someone can help me with this issue?
Hi tomcatyou,
The fix for development issue #108470 has been released. Upgrading your product version to the latest SR should resolve the matter.
Please do not hesitate to contact me if you need more information.
Hello tomcatyou,
I've created a support ticket in your behalf with number CAS-88893-9ZSB6X in regard to the issue reported by you. You can contact me through it on the following link: https://ko.infragistics.com/Membership/MySupport.aspx . Currently there's a logged development issue in our tracking system - #108470 - "Only the first grouped row is collapsed with initialExpand: false" which is in review , as soon as a resolution is reached you will be notified through the support ticket created.
Hi again,
Thanks for the explanations, it seems to be an issue, our developers looking into, so as soon as I have an update I will write back.
I got your point, Let me check out what can be done.
Yes, It's the right sample.
First keep "Standard Cost" collapse.
Then collapse or expand the Color group. the "Standard Cost" will expand when expand the Color Group.
Thanks again for your reply.
