I have a subecription bu I cannot access the site with my other user name ben999.Is it possible to remove weekends from the selection or disable them like in the jquery alternative.
Kind Regards
Matt
Hi Ben,
I have created a case on your behalf in order to find out what is the reason to experience this issue with your other account.
I will update you through the case created.
The case number is - CAS-91974-3V17ZL
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
Fixed it, see below. Can you please fix my ben999 account.
ThanksBen
<script type="text/javascript"> function nonWorkingDates(date){ var day = date.getDay(), Sunday = 0, Monday = 1, Tuesday = 2, Wednesday = 3, Thursday = 4, Friday = 5, Saturday = 6; var closedDates = [[7, 29, 2009], [8, 25, 2010]]; var closedDays = [[Sunday], [Saturday]]; for (var i = 0; i < closedDays.length; i++) { if (day == closedDays[i][0]) { return [false]; }
for (i = 0; i < closedDates.length; i++) { if (date.getMonth() == closedDates[i][0] - 1 && date.getDate() == closedDates[i][1] && date.getFullYear() == closedDates[i][2]) { return [false]; } }
return [true]; }
$(function () { $('#picker).igDatePicker({ width: 185, datepickerOptions: { beforeShowDay: nonWorkingDates } }); }); </script>
