Using jquery 1.7.2 and enabling rowVirtualization is giving me some strange behavior. Whenever I scroll up with the mouse wheel the grid scrolls down instead. I haven't checked this with any other 1.7.x versions, but it doesn't happen with 1.6.2.
Is this a known issue or is there any workaround to fix it?
Hello Luisrh,
If need further assistance on this case do not hesitate to contact us.
I hope you were able to handle this.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
This issue starts to reproduce with jQuery 1.7.x. The problem is already fixed. If you are using 11.2 version you will receive the bug fix with the next Service Release. You can also upgrade to newly released 12.1 version if you prefer.
Ivan
