How we can desactive the auto multi-level (one property/Css ?) ?
I've an IQueryable List of object and for each object I have a List of an other object.
If I do not configure Childlayout, the multi-level render my objects in the ListView (OK) and render too the childs (KO) and then override the NavigateUrlKeyFor (to an url.action) property of my list.
Thanks a lot.
Hi Jérôme,
You are correct about this. I have submitted bug 111888 for this. The problem it seems is that we might skip generating the layouts on the server, but it still tried on the client. This should be in the first service release. If you want to fix this in the meantime, you could modify the list view javascript inside
dataBind: function() { for the igListView (not igList).
Changeif (this.options.autoGenerateLayouts) {toif (this.options.autoGenerateLayouts === true) {
regards,David Young
Hi, I've a AutoGenerateLayouts (not AutoGenerateChildLayouts) on the top level and that does not work for me...
<%= Html.InfragisticsMobile().ListView<Ecurie>() .DataSource(Model) .ID("myListView") .AutoGenerateLayouts(false) //.Inset(true) .ImageMode(Infragistics.Web.Mvc.Mobile.ImageMode.ThumbNail) //.ShowCount(false) //.ItemTheme("b") .Bindings(b => { b.HeaderKeyFor(e => e.Nom) .ImageUrlKeyFor(e => e.UrlImage) .DescriptionKeyFor(e => e.Description) .CountKeyFor(e => e.NbTitres) .TextKeyFor(e => e.Resume) .CustomBindingFor(e => e.Nationalite); //Utile pour des action en local sur les filtres/classements. //.NavigateUrlKeyFor(e => e.Url);//mettre en // si multi-level
Thanks in advance,
Jérôme.
Hi CubeRaptor,
If I understand your question correctly, you do not want us to generate the child layout? You should set AutoGenerateChildLayouts to false on the top level. Whenever, there are children present, the navigate url is ignored as we need to navigate to a dynamic sub page holding the children instead.
Hi, there is the "data-initial-data-bind-depth" property.
How can I use that property with the Html Helper ?
<%= Html.InfragisticsMobile().ListView<Ecurie>() .DataSource(Model) .ID("myListView") ...
