95
How to use delegated version of Jquery .on() with infragistics events
The code below works.  The .on() function in JQuery is can attach the event.  However, if I replace the combo with AJAX, I have to attach again.  I would like to use the delegated version of the .on() function.  In this example, The commented out code does not work.  I also tried the delegate syntax that has been suggested elsewhere on this forum.  I am using JQuery 1.7.1 specifically for the .on() functionality, and I have verified it works on normal html events.  I am using 12.1 infragistics.  I placed the script at the end to show that the script is executing after the MVC helper is done.
    var comboModel = new ComboModel {
        DataSource = new [] { "fee","fi", "fo","fum"},
        InputName = "TestCombo",
        ID = "TestComoboTarget"
<div id="comboTestContainer">
@Html.Infragistics().Combo(comboModel)
</div>
    $(document).ready(function () {
        //This code works
                        $('span#TestComoboTarget').on('igcomboselectionchanged', function () {
                            alert('hello');
        //This does not work
        //        $('div#comboTestContainer').on('igcomboselectionchanged', 'span#TestComoboTarget', function() {
        //            alert('hello');
        //This also does not work
        //        $(document).delegate("span#TestComoboTarget", "igcomboselectionchanged",
        //            function (evt, ui) {
        //                alert('hello');
</script>
