410
igGrid and igCombobox
I would like to know if there is a way for the igGrid and igCombobox to return back to the server only the data for the columns that are defined in the list of columns.
Here is an example:
igGrid and igCombobox list of Columns: ID, Code.
Datasource Columns: ID, Code, Name, Description, Quanity, Price, etc..
I want the helper to only return the data for ID and Code and ignore the rest.
  • 6279
    If I've understood you correctly, this might be the solution you're looking for:
    http://stackoverflow.com/questions/9878983/ignore-a-property-while-using-jquery-extend
    The trick would be that you need to iterate through the records of the igGrid's dataSource, extend each one into a temp  variable which you can then push into an array and then send that array (its objects will contain ID and Code only) to the server-side via AJAX.
    I think this approach would work for you, but if it doesn't can you please provide me a few clues as to why do want to transmit just a "windowed" version of the grid and combo's data to the server.
    The more understanding I have of the need behind the scenario, the better a sample I can provide for you.
    Cheers,
    Borislav
