Hi, I am using Infragistics Upload control in Asp.net MVC3 application, I found there is a link button called "Clear Uploaded", what it will do after I click it? What I can see if the uploaded file names disappeared, did it remove the files on the server?
Thank you.
That's I was implemented. I remove it and create it via javascript.
Could you please answer my last question?
I found that the igUpload will replace the file already existed if uploaded file has the same name. I added some code in Global.asax.cs to check if the file exists, if so, change the uploaded file name by adding some unique information like timestamp.
I want to get the changed file name at the client side, how can I do that?
Hi again,
In order to bring it back to its initial state I suggest that you destroy and reinit the widget.
If you need API reference, here is where it is located:http://help.infragistics.com/jQuery/2012.1/ui.igupload
I have one more question, I want to reuse the igUpload control, once uploaded files, I want to set this control to default status, that is only one "Upload" button, how can I do that?
Hi there,
This simply clears the UI. It would not remove the uploaded files.
Thank you for using the Infragistics forums!
