I need to bind the datasource for JQuery grid from WCF service. The WCF service returns list. The WCF service is as follows.
I am receiving the below error:
Microsoft JScript runtime error: The remote request to fetch data has failed: (parsererror) There was an error parsing the JSON data and applying the defined data schema: 'length' is null or not an object
Please let me know on how to bind the data from wcf service.
Below is the code for WCF service
namespace InfraApplication
// NOTE: You can use the "Rename" command on the "Refactor" menu to change the class name "SampleService" in code, svc and config file together.
[AspNetCompatibilityRequirements(RequirementsMode = AspNetCompatibilityRequirementsMode.Allowed)]
public class SampleService : ISampleService
public void DoWork()
public List<CustomerViewModel> GetSortedCustomers()
List<CustomerViewModel> cvml = new List<CustomerViewModel>();
CustomerViewModel cvm = new CustomerViewModel();
cvm.CompanyName = "ABC Company";
cvm.ContactName = "Krishna";
cvml.Add(cvm);
return cvml;
public class CustomerViewModel
public string ContactName { get; set; }
public string CompanyName { get; set; }
Hello ,
Thank you for your update.As I've mentioned before it all depends on the implementation of your WCF service and the structure of JSON.There is sample attached in the article below:
http://help.infragistics.com/NetAdvantage/jquery/2012.1?page=igGrid_Getting_Started_With_igGrid_oData_and_WCF_Data_Services.html
which you may use as starting point
http://dl.infragistics.com/community/jquery/codesamples/aaronm/2011-07-28/igGridOData.zip
Hope this helps
On removing responseDataKey: "d", the code was working fine. But when i try to bind the same using the list from the database, I am getting the below error
By looking the code snippet I can guess that the issue in your case is the missing JSON format at the end
dataSource: "/SamplesBrowser/Services/WCFCustomerService.svc/GetSortedCustomers?$format=json",
But it depends on the realization of ISampleService interface.
For example in our sample browser we have similar one
http://samples.infragistics.local/jquery/grid/binding-to-wcf-service
In your scenario I noticed that you are using similar to our WCFCustomerService.svc which is implementing
public interface IWCFCustomerService { [OperationContract] [WebGet(ResponseFormat=WebMessageFormat.Json)] List<CustomerViewModel> GetSortedCustomers(); }
Using it as datasource I didn't have to set responseDataKey in my HTML sample
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head> <script type="text/javascript" src="/SamplesBrowser/Scripts/modernizr.min.js"></script> <script type="text/javascript" src="/SamplesBrowser/Scripts/jquery.min.js"></script> <script type="text/javascript" src="/SamplesBrowser/Scripts/jquery-ui.min.js"></script> <script src="http://localhost/ig_ui/js/infragistics.loader.js"></script> <script type="text/javascript"> $.ig.loader({ scriptPath: "http://localhost/ig_ui/js/", cssPath: "http://localhost/ig_ui/css/", resources: "igGrid.*" }); $.ig.loader(function () { $("#grid1").igGrid({ height: 500, columns: [ { headerText: "Company Name", key: "CompanyName", dataType: "string" }, { headerText: "Contact Name", key: "ContactName", dataType: "string" }, ], autoGenerateColumns: false, dataSource: "/SamplesBrowser/Services/WCFCustomerService.svc/GetSortedCustomers?$format=json", // responseDataKey: "d", features: [ { name: "Paging", type: "local", pageSize: 10 }, { name: "Filtering", allowFiltering: true, type: "local" } ] }); }); </script> <style type="text/css"> #selection_list { border: 1px soild; width: 600px; height: 200px; overflow-y: scroll; background-color: #EBEBEB; } </style></head><body> <br /> <table id="grid1"> </table></body></html>
I recommend you using the Developer Tools of IE9 or Firebug to check what is the structure of JSON .
Also you may find this article as helpful:
Let us know if you need further assistance
