How can I implement the stacked column chart? See the attachment.
I am attempting to implement a stacked series (bar) with the latest igDataChart and the MVC web helper. There is a sample of Stacked Series igDataCharts on the infragistics.com website, but it appears that the sample code for all but the controllers was accidentally left out.
http://ko.infragistics.com/products/jquery/sample/chart/stacked-series
Ramon, you may want to hold on as stacked series are coming in a more official fashion pretty soon.
How to translate this in razor code?
thanks men
Stacked column charts are a future feature of the igDataChart. If you submit a feature request it will help to make sure that the feature is prioritized correctly.In the interim, you can emulate a stack column chart by summing the data yourself and using the overlap property of the x axis as in this example:
<script> $(function () { var data = [{ category: 'shoes', bob: 5, david: 6, jen: 10 }, { category: 'hats', bob: 15, david: 8, jen: 11 }, { category: 'coats', bob: 7, david: 6, jen: 9 }, { category: 'slippers', bob: 7, david: 2, jen: 12 }], stackData; stackData = function (data, order) { var i, j, accum; for (i = 0; i < data.length; i++) { accum = 0; for (j = 0; j < order.length; j++) { accum += data[i][order[j]]; if (j > 0) { data[i][order[j] + "_sum"] = accum; } } } } console.log(data[0]); stackData(data, ["bob", "david", "jen"]); $("#container").igDataChart({ width: "500px", height: "500px", dataSource: data, axes: [{ name: "xAxis", type: "categoryX", label: "category", overlap: 1 }, { name: "yAxis", type: "numericY", minimumValue: 0 }], series: [{ name: "jen", title: "jen", type: "column", xAxis: "xAxis", yAxis: "yAxis", valueMemberPath: "jen_sum" }, { name: "david", title: "david", type: "column", xAxis: "xAxis", yAxis: "yAxis", valueMemberPath: "david_sum" }, { name: "bob", title: "bob", type: "column", xAxis: "xAxis", yAxis: "yAxis", valueMemberPath: "bob" }], horizontalZoomable: true, verticalZoomable: true, windowResponse: "immediate", overviewPlusDetailPaneVisibility: "visible", legend: { element: "legend" } }); }); </script>
which produces the following output:
