80
NEed help with ig.loader sample from the docs
I found an example for the loader here and tried to modify it a little bit, because I do not have adventureworks.js, but then I got multiple errors and I cant figure out the problem using FireBug because the errors are somewhat vague for me. Here is my the code. Please point me the errors :
<!doctype html>
<html>
<head>
    <!-- jQuery Core -->
    <script src="js/jquery-1.7.2.min.js" type="text/javascript"></script>
    <!-- jQuery UI -->
    <script src="js/jquery-ui-1.8.21.min.js" type="text/javascript"></script>
    <!-- Infragistics Loader Script -->
    <script src="ig/js/infragistics.loader.js" type="text/javascript"></script>
    <!-- Infragistics Loader Initialization -->
     var products = [
     { "ProductID": 1, "Name": "Adjustable Race", "ProductNumber": "AR-5381" },
     { "ProductID": 2, "Name": "Bearing Ball", "ProductNumber": "BA-8327" },
     { "ProductID": 3, "Name": "BB Ball Bearing", "ProductNumber": "BE-2349" },
     { "ProductID": 4, "Name": "Headset Ball Bearings", "ProductNumber": "BE-2908" },
     { "ProductID": 316, "Name": "Blade", "ProductNumber": "BL-2036" },
     { "ProductID": 317, "Name": "LL Crankarm", "ProductNumber": "CA-5965" },
     { "ProductID": 318, "Name": "ML Crankarm", "ProductNumber": "CA-6738" },
     { "ProductID": 319, "Name": "HL Crankarm", "ProductNumber": "CA-7457" },
     { "ProductID": 320, "Name": "Chainring Bolts", "ProductNumber": "CB-2903" }
        $.ig.loader({
            scriptPath: "ig/js/",
            cssPath: "ig/css/",
            resources: "igGrid.Sorting"
        $.ig.loader(function () {
            $("#grid1").igGrid({
                autoGenerateColumns: false,
                columns: [
                    { headerText: "Product ID", key: "ProductID", dataType: "number" },
                    { headerText: "Product Name", key: "Name", dataType: "string" },
                    { headerText: "Product Number", key: "ProductNumber", dataType: "string" }
                dataSource: products,
                height: "400px",
                features: [{
                    type: "local",
                    mode: "multiple"
    </script>
</head>
<body>
    <table id="grid1"></table>
</body>
</html>
  • 80
    Verified Answer
    The example runs fine. I have made a spelling mistake - the ui javascript file name is jquery-ui-1.8.21.custom.min.js. :) Moderators, please delete this post. It is useless.
