115
knockout extension bug when removing an item from an observable array binded to a igGrid
We have an observable array wich is bound to an igGrid.
When removing an item from the observable array the grid should be updated, but instead a javascript error is thrown.
After investigating we found that the problem occurs in the following file.
Infragistics.UI.grid.knockout-extensions.js
There is a typo in the javascript, a variable 'olds' is used where it should be 'oldds' !
After changing this typo at 2 places, we found that this solved the problem.
Could you have a look into this issue, so other people using the knockout extension wont have this bug.
Greetings,
Christophe
