For example, if markerType="triangle" used, is it possible to change the size of the triangle?
[Infragistics] Lazar Videnov said:;
Can we set marker outline color to be same as the brush color of line ?
It works! Thank you very much!
Hello, cgaoI developed a sample for you which draws scatter series with triangle markers with settings for triangle size and color. It is based on custom marker as Nikifor suggested earlier. Please, find the sample attached. Just to be clear, I'll explain the most important parts: 1. Setting custom marker template. The markerTemplate option is configured with a marker template object.
2. Basic structure of the custom marker object. The measure and render methods are called by the chart widget to draw a custom marker. The extent parameter defines how large the triangle will be.
3. Triangle drawing logic. The logic uses the marker coordinates as a center of a circle and draws a unilateral triangle in this circle.
I hope this can provide you the required functionality. Post here if you need some additional questions.Cheers, Lazar
Hello Chao,
You can create a custom marker in order to achieve this. It is far more complex. A good explanation is discussed in the following forum thread - http://ko.infragistics.com/community/forums/t/71724.aspx
Currently we do not offer this functionality. I have logged a feature request with id PI12080043. I have sent this product idea directly to our product management team. Our product team chooses new product ideas for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time.
If you would like to follow up on your product idea at a later point, you may contact Developer Support management via email. Please include the reference number of your product idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
