65
Intercepting iGCombo filter text
I am currently trying to intercept the search text provided by the igCombo on autocomplete remote filtering.
This works, (below ) although it seems that when I tab away from the combo box a UI event clears my selection.
Json data totals seems to get lost when you customize the Query on the web server (i.e. ...,{":totals:":"1:8"}]
I am assuming this is a common issue with the combo box, because it's pretty standard to want to customize the query
based on the text provided in the combo box.
Is there a way to prevent the combo box from bieng cleared out during the "blur" event?
[ComboDataSourceAction]         [ActionName("filtering-data")]         public ActionResult ComboGetData()         {                          var mainQuery = products.AsQueryable();             NameValueCollection col = this.HttpContext.Request.QueryString;             string filterName = col["filter(FullName)"];             if (filterName != null)             {                 string filterArgs = filterName.Substring(9).Replace(")"String.Empty).ToLowerInvariant();                 mainQuery =                     mainQuery.Where(                         p =>                         p.Name.ToLowerInvariant().StartsWith(filterArgs)                         || p.Name2.ToLowerInvariant().StartsWith(filterArgs)).AsQueryable();             }             var ds = mainQuery;             return View(ds);         }
Any help will be appreciated.
I managed to get the correct behaviour in the UI during filtering which is why I thought I had the solution as per (http://ko.infragistics.com/community/forums/t/72010.aspx) but due to a UI event clearing out the control when it loses focus I am back to square 1.
Jean
  • 24497
    Hi Jean,
    The igCombo with default options does not allow a value which is not present in current dataSource. On blur event the igCombo tries to find a matching item for current text. If item is not found, then text is considered illegal and value/text is cleared.
    The igCombo has option/property allowCustomValue, which disables "match" validation. However, functionality of igCombo with that option is quite different and application should not assume that value in igCombo represents an item in dataSource.
