210
Unable to get vanlue of DatePicker
I am using the DatePicker to build a Query but I can't get the value of the component
I'm using MVC3 in combination with vb.net
below are my model controller and view
model:
Imports System.ComponentModel
Imports System.ComponentModel.DataAnnotations
Imports System.Globalization
Imports Infragistics.Web.Mvc
Imports System.Linq
Public Class FilterPartialModel
Private bla As String
<Display(name:="Start date filter")> _
Public Property StartDateTime As DateTime
<Display(name:="End date filter")> _
Public Property EndDateTime As DateTime
<Display(name:="Select the sate you want to see")> _
Public Property StateName As String
Get
Return TrackingUser.Instance.NameStateFilter
End Get
Set(value As String)
TrackingUser.Instance.NameStateFilter = value
End Set
End Property
<Display(name:="State list")> _
Public Function States() As SelectList
Return New SelectList(createList)
End Function
Private Function createList() As Collections.IEnumerable
Dim col As New Collection
col.Add("All")
col.Add("Open")
col.Add("Pause")
col.Add("In progress")
col.Add("Closed")
Return col
End Function
End Class
controller:
Imports System.Diagnostics.CodeAnalysis
Imports System.Security.Principal
Imports System.Web.Routing
Namespace MvcApplication2
Public Class OverViewFilterPartialController
Inherits System.Web.Mvc.Controller
' GET: /OverViewFilterPartial
Function Index() As ActionResult
Return View()
End Function
<HttpPost()> _
Function Filter(ByVal model As FilterPartialModel) As ActionResult
Try
TrackingUser.Instance.StartDateFilter = model.StartDateTime
Catch ex As Exception
TrackingUser.Instance.StartDateFilter = DateTime.Now.AddYears(-1)
End Try
Try
TrackingUser.Instance.EndDateFilter = model.EndDateTime
TrackingUser.Instance.EndDateFilter = DateTime.Now
End Try
TrackingUser.Instance.NameStateFilter = model.StateName
Return RedirectToAction("OverView", "Home")
Return View()
End Function
End Class
End Namespace
view:
@Imports Infragistics.Web.Mvc
@ModelType MvcApplication2.FilterPartialModel
@Code
ViewData("Title") = "OverViewFilterPartial"
End Code
<script src="@Url.Content("~/Scripts/jquery.validate.min.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/jquery.validate.unobtrusive.min.js")" type="text/javascript"></script>
@Using Html.BeginForm("Filter", "OverViewFilterPartial", FormMethod.Post)
@<div>
<table width="100%" border="0" cellspacing="0" cellpadding="0">
<tr>
<td width="30%">
<div>
@Html.LabelFor(Function(m) m.StartDateTime)
@(Html.Infragistics.DatePickerFor(Function(m) m.StartDateTime).ID("StartDateTimePicker").Width(150).DateInputFormat("dateTime").Value(Model.StartDateTime).NullText("Enter Start Filter Date").ValidatorOptions(Function(m) m.AnimationShow(0).AnimationHide(0).OnBlur(False).OnChange(False).OnSubmit(False).KeepFocus(ValidatorKeepFocus.Always)).Render())
</div>
</td>
<td width="30%">
<div>
@Html.LabelFor(Function(m) m.EndDateTime)
@(Html.Infragistics.DatePickerFor(Function(m) m.EndDateTime).ID("EndDateTimePicker").Width(150).DateInputFormat("dateTime").Value(Model.EndDateTime).NullText("Enter End Filter Date").Render())
</div>
</td>
<td width="30%">
<div>
@If Model IsNot Nothing Then
@Html.LabelFor(Function(m) m.StateName)
@Html.DropDownListFor(Function(m) m.StateName, Model.States)
End If
</div>
</td>
<td width="10%" >
<div>
<p>
<input type="submit" name="Filter" value="Filter" />
</p>
</div>
</td>
</tr>
</table>
</div>
End Using
as soon as I press the filter button I get het value: #12:00:00 AM# instead of the date i entert, help please?
Best regards,
Daniel van Cann
  • 24497
    Hi Daniel,
    Within controller the model.StartDateTime and EndDateTime should provide values entered on client.
    Though, after a postback the editors on client will get their original values, because application sets Value after editors were created. The editor gets value from client within its creation which is DatePickerFor(...). All following chained statements override any current values, so, statement like ...Value(Model.StartDateTime)... will lock value of editor to model.StartDateTime. If that is what is intended, but problem is in get-value within controller, then try to figure out what causes that. For example, temporary remove validation, initial-Value statements, etc.
