Can I maintain the state of igGrid. Suppose the user is on Page 2 in grid and with filter set on one column.
Next time user visited the same page and I bind data and set page number 2 and filter row open and fill the filer column textbox with the same old value
Anilesh
Hi Angel,
I'm also keen to use a persistence framework for igGrid - you mention that you plan to release one, can you give an approximate timescale?
John.
You can definitely do so, using the grid API, along with some HTML5 feature such as Local Storage. You can also use cookies, but i suggest local storage, if your supported browsers support it.
You can have a look at the following API docs in order to see how you can retrieve various settings, such as the current page index, filtering expressions, etc. You can obtain the filtering expressions in the following way:
$("#grid1").data("igGrid").dataSource.settings.filtering.expressions
http://help.infragistics.com/jQuery/2012.1/
We are planning to have a full blown persistence framework, as part of the next releases.
Hope it helps.
Angel
