1150
setting valueKey of igCombo as editor clears text in edit mode
I noticed that on entering edit mode, when I set only the TextKey, combo editor displays default value text, but if I set the ValueKey, the text is empty. Is there a way around to fix this ?
I noticed that the _oldCellVal property is null when this happens, I tried setting that property on editCellStarting and Started without success. I've also tried setting the selectedItems and text under options property, but that also didn't work.
  • 1150
    Verified Answer
    For some reason, setting AllowCustomValue(true) when setting up the combo editor in the MVC razor view solves this issue.
