Hi
I am working on MVC Razor. And i have a hierarchical-grid in a view which has few editable columns.
Also, there are radio buttons, and on click of those buttons following operations are perforemed:
And for above operations, i want to write a jquery method for above tasks. Although, got through few posts but can't find, how to loop through all rows of grid and how to access cell value.
Heloo Amit,
Thank you for posting in our forums.
You can use "allRows" method to get all rows of the current grid instance.
http://help.infragistics.com/jQuery/2012.1/ui.iggrid_hg#methods
You should iterate through the rows and access the cell value using "getCellValue" method
I recommend you using the summary feature for the "Sum" requirement
http://ko.infragistics.com/products/jquery/sample/grid/column-summaries-basic-options
Since v12.2 there will be Unbound Column in igGrid so you can take advantage of this for the "value of 1 column is copied to another column" requirement.
Hope this helps.
