Hello.
Does anyone have a working example of how to use this control using the ASPX engine? The example that comes with the download is too intertwined with the web page, so it's a little bit difficult to reproduce only the pivot grid with remote XMLA server.
Best regards.
Hi Mauricio,
Attached you can find pure JavaScript sample demonstrating igPivotGrid. The reason I didn't put it in MVC project is that currently there are no MVC Wrappers for igPivotGrid.
You need to change Infragistics Loader cssPath and script path to point to your local Infragistics Ignite UI installation folder in order to make it work.
Please note that this is CTP functionality.
Hope this helps,
Martin Pavlov
Infragistics, Inc.
That's great.
Ask them to do it with the remote server setup.
Best regards,
Mauricio
hi Mauricio,
I have asked our team to follow up with an isolated sample in a zip file.
thanks
Angel
