1930
Sorting dinamically error : unable to get the property 'show': object is null or undefined
Hi
i'm using iggrid in my mvc razor application and it works great, but there is a problem when try to sort a column dinamically and i get error.
This is the error i get : Microsoft JScript runtime error : unable to get the property 'show': object is null or undefined. In file ig.grid.ui.min.js the.
(i've attacched a picture to show the error)
This is how i try to sort the column dinamically:
$(document).delegate("#gridVistaArticoli", "iggriddatarendered", function (evt, ui){
     $('#gridVistaArticoli').igGridSorting('sortColumn', 1, 'ascending');
     or
     $('#gridVistaArticoli').igGridSorting('sortColumn', 'StagioneCodice', 'asc');
     $('#gridVistaArticoli').igGridSelection('selectRow', 5);    //This works fine
This is how igGrid look like :
@(Html.Infragistics().Grid<InfoCopy.SuiteInBlu.SuiteArticoliServiceReference.VistaArticoli>()
    .ID("gridVistaArticoli")
    .AutoGenerateColumns(false)
    .AutoGenerateLayouts(false)
    .Columns(column =>
            column.For(x => x.Codice).DataType("string").HeaderText("Codice").Width("8%");
            column.For(x => x.ColoreCodice).DataType("string").HeaderText("Colore").Width("5%");
            column.For(x => x.StagioneCodice).DataType("number").HeaderText("Stagione").Width("6%");
            column.For(x => x.CampionarioCodice).DataType("string").HeaderText("Campionario").Width("9%");
            column.For(x => x.Descrizione).DataType("string").HeaderText("Descrizione").Width("27%");
            column.For(x => x.DittaCodice).DataType("string").HeaderText("Ditta").Width("5%");
            column.For(x => x.LineaCodice).DataType("string").HeaderText("Linea").Width("5%");
            column.For(x => x.MaterialeCodice).DataType("string").HeaderText("Materiale").Width("6%");
            column.For(x => x.Cod_Variante).DataType("string").HeaderText("Variante").Width("10%");
            column.For(x => x.Barcode).DataType("string").HeaderText("Codice a Barre").Width("9%");
            column.For(x => x.PathImg).HeaderText("Immagine").Template(ImageTemplate).Width("7%");
            column.For(x => x.ID_Articolo).DataType("number").HeaderText("ID").Width("10%");
    .Features(features =>
            features.GroupBy().GroupBy.EmptyGroupByAreaContent = "Drop column here to group";
            features.Paging().PageSize(Model.gridPageSize)
                .PrevPageLabelText("Previous")
                .NextPageLabelText("Next")
                .PageSizeDropDownTooltip("Select page")
                .ShowPageSizeDropDown(false)
                .CurrentPageIndex(@Model.GridPageIndex);
            features.Sorting().Mode(SortingMode.Single).ColumnSettings(settings =>
                settings.ColumnSetting().AllowSorting(true);
            features.Filtering();
            features.Resizing().AllowDoubleClickToResize(true).DeferredResizing(true).ColumnSettings( s=>
                s.ColumnSetting().ColumnKey("PathImg").AllowResizing(false);
            features.Selection().MouseDragSelect(true).MultipleSelection(true).Mode(SelectionMode.Row);
            .ClientDataSourceType(ClientDataSourceType.JSON)
            .DataSourceUrl(Url.Action("GetVistaArticoli"))
            .Width("100%")
            .LocalSchemaTransform(true)
            .DataBind()
            .Render()
Parents
No Data
Reply
  • 24671
    Suggested Answer
    could you use the "iggridrendered" event instead of the "iggriddatarendered" ? the loading indicator is common to the whole grid so it may not be loaded once iggriddatarendered fires.
    Angel
Children
No Data
