I have a licensed copy of NetAdvantage Ultimate 12.2. I've created a new ASP.NET MVC4 Web Application Project and I used igGrid. When I started application the label "IgniteUI Trial Version" appears in right lower corner of the page. The instalation of the NetAdvantage Ultimate was without problems. How to remove the label?
I opened sample application project and compile it and run it and there is no label for trial.
So I think this has been resolved. For me I think the watermark was being cached, and so do what I might to the code the front end was always showing the watermark. I cleared my cache and the watermark went away. Not sure if that is everyones problem, but I believe it is what I was experiencing.
I have just uninstalled the trial version and installed the licensed version and am still seeing the IgniteUI Trail Version at the bottom of the page. Is there a solution to this?
I have the same issue and i am on the latest fix .2056
Hello Ian,Just following up to check what is the result of fresh downloaded product.
I'll try downloading again and seeing if that changes.
palmertj - Unfortunately, we develop for some clients that either massively restrict outside internet access, or restrict it all together and run our site internally. They need the files local.
