2048
IgHierarchicalGrid and CRUD operations on children
I've implemented an igGrid with relative igHierarchicalGrid. I set updating feature on the first grid and the same on the second one (child grid).
It works correctly for both grids, but the problem is the following one: if I have a row without children I am not able to create new ones, because I can't see '+' expand character and I am not able to open the child grid...
How can I have a child grid also for those rows that do not have children?
Flavio
  • 2048
    posted in reply to [Infragistics] Tsvetelina Georgieva
    That's ok.
    I started working on igHierarchicalGrid with Load on Demand.
    I followed up this sample:
    http://ko.infragistics.com/products/jquery/sample/hierarchical-grid/hierarchical-grid-load-on-demand
    and this little manual:
    http://help.infragistics.com/Help/NetAdvantage/jQuery/2012.2/CLR4.0/html/igHierarchicalGrid_Load_on_Demand.html#loadOnDemandMVC
    I am in the case of MVC controller side hierarchical grid (C# syntax).
    I think I completely did all the things I found in the sample and in the manual page...so, my code is the following one:
            public ActionResult Index()
                GridModel gm = new GridModel();
                _createGridModel(gm);
                return View(gm);
            public JsonResult BindParent()
                ...loading parentObjectList as List<ParentObject>()
                gm.DataSource = parentObjectList .AsQueryable();
                    return gm.GetData();
            public JsonResult BindChild(string path, string layout)
                ...loading childrenObjectList as List<ChildrenObject>()
                gm.DataSource = childrenObjectList .AsQueryable();
                    return gm.GetData(path, layout);
            private GridModel _createGridModel(GridModel gm)
                gm.ID = "parent_grid";
                gm.AutoGenerateColumns = false;
                gm.AutoGenerateLayouts = false;
                gm.PrimaryKey = "Id";
                gm.Width = "100%";
                #region Grid Columns
                gm.Columns.Add(new GridColumn("Id", "Id", "number", "0"));
                gm.Columns.Add(new GridColumn("Description", "Description", "string", "35%"));
                gm.RenderCheckboxes = true;
                #endregion
                #region Grid Hiding
                GridHiding hiding = new GridHiding();
                ColumnHidingSetting hSetId = new ColumnHidingSetting();
                hSetId.ColumnKey = "Id";
                hSetId.AllowHiding = false;
                hSetId.Hidden = true;
                hiding.ColumnSettings.Add(hSetId);
                ColumnHidingSetting hSetDescription = new ColumnHidingSetting();
                hSetDescription .ColumnKey = "Description";
                hSetDescription .AllowHiding = false;
                hSetDescription .Hidden = false;
                hiding.ColumnSettings.Add(hSetDescription );
                gm.Features.Add(hiding);
                #endregion
                #region HierarchicalGrid
                GridColumnLayoutModel hgml = _getHierarchicalGridColumnLayout();
                gm.ColumnLayouts.Add(hgml);
                #endregion
                    gm.LoadOnDemand = true;
                    gm.DataSourceUrl = Url.Action("BindParent");
                    gm.ColumnLayouts[0].DataSourceUrl = Url.Action("BindChild");
                return gm;
            private GridColumnLayoutModel _getHierarchicalGridColumnLayout()
                GridColumnLayoutModel hierarchicalGm = new GridColumnLayoutModel();
                hierarchicalGm.ID = "hgrid";
                hierarchicalGm.AutoGenerateColumns = true;
                hierarchicalGm.AutoGenerateLayouts = false;
                hierarchicalGm.Key = "Allegati";
                hierarchicalGm.PrimaryKey = "Id";
                hierarchicalGm.ForeignKey = "DispositivoId";
                hierarchicalGm.Caption = "Allegati";
                hierarchicalGm.Width = "100%";
                return hierarchicalGm;
    But I still get this error:
    Error: The remote request to fetch data has failed:  (error) undefined @ ...Scripts/IG/modules/infragistics.ui.grid.framework.js:25
    I also tried to set data binding on js code:
         $(function () {
             $("#grid_anagrafica_tipologie_dispositivo").live("iggriddatabinding", function (evt, ui) {
                 $("#grid_anagrafica_tipologie_dispositivo").igGrid("option", "dataSourceType", "json");
    But the result is the same...
    Note that parent grid has been creating right: I can see all the objects with a '+' on the left. The problem is when I try to expand a parent record into its children: I can see the subgrid rendering with all the columns, but the application stops with the loading picture thread, and I can see on the debugging console the error mentioned above...
    Through the debug I can see that BindChild method is correctly reached, and the error is given here, at the end of the code:
    returns a null object exception...
    I don't know if I forgot some properties to be set, or if I did something wrong in the datasource/databinding management...
    Thanks in advance!!!!
    Flavio
  • 19693
    Hello Flavio,
    Thank you for posting in our forums.
    I think that a similar question of yours was answered some time ago by Angel Todorov
    http://ko.infragistics.com/community/forums/p/66844/337969.aspx#337969
    You need to enable Load on demand (LoadOnDemand = true in the MVC wrapper, or set initialDataBindDepth to 0 in the options, if you are using just the client-side widget).
    Hope this helps.
