I would like to have a dropdown column in the igGrid that will dropdown and display a 3 column grid with ID, DisplayName and Code. May I know if there is any example that I can follow or resource that I can reference how to achieve that? thanks so much.
Hello aschoi,
The property that you are looking for is dropDownWidth
http://help.infragistics.com/jQuery/2012.2/ui.igcombo#options
Hope this helps.
Thanks. it seems partially working now. However, I have a problem to set the width of the dropdown of the combo editor to allow it to show all the columns in the grid. I tried with "listWidth", "width" but no luck. Could you please let me know how to set of the dropdown width so that all 3 columns can be shown.
Hello aschoi ,
You can set a template for the combo for the header, item and footer templates. You can see something similar here:http://ko.infragistics.com/products/jquery/sample/combo-box/templating
Since you can use the combo as an editor of the grid you can just add to it the corresponding template you want. A sample of hos to add a combo box as an editor of the grid you can find here:http://ko.infragistics.com/products/jquery/sample/combo-box/grid-editor
So you can add a template to display the data you want and style it to appear as a table. I’m attaching a simple sample for your reference.
Let me know if you have any questions or concerns or if yoy need further assistance.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
