I am developing a tablet solution and want to support IE10 on a Win 8 tablet. I am presenting dashboards using the igDataChart and the interaction for showing the detail behind a data point is to tap-and-hold a data point. After a 750ms delay the details slide down from the top of the screen. This all works well with desktops and iPad, but on IE 10 the tap-and-hold has a behaviour where the chart will zoom in every 500ms or so i.e. keeps jumping to a higher zoom level, which means the tooltip is not displayed.
Any ideas how I can turn off this behaviour for IE10?
My JS code is below:
$('#single-analysis').igDataChart({ width: self.vars.paneWidth + 'px', height: (self.vars.paneHeight - 50) + 'px', theme: 'metro', dataSource: (isColAndLine || isScatter || isBubble) ? null : new $.ig.DataSource({ type: 'json', dataSource: data.DataPoints }), axes: chartAxes, series: chartSeries, horizontalZoomable: true, verticalZoomable: true, showTooltips: false, windowResponse: 'immediate', crosshairVisibility: 'hidden', seriesMouseEnter: function(evt, ui) { self.cancelDetailOnDemand(evt); }, seriesMouseLeave: function(evt, ui) { self.cancelDetailOnDemand(evt); }, seriesMouseMove: function(evt, ui) { var posX = self.vars.positionX, posY = self.vars.positionY, newPosX = ui.positionX, newPosY = ui.positionY; console.log('posX: ' + posX + ' newPosX: ' + newPosX + ' posY: ' + posY + ' newPosY: ' + newPosY); // Only cancel DoD if position has moved more than 10 pixels if (newPosX > (posX + 20) || newPosX < (posX - 20) || newPosY > (posY + 20) || newPosY < (posY - 20)) { self.cancelDetailOnDemand(evt); } else { preventEventBubble(evt); } }, seriesMouseLeftButtonDown: function(evt, ui) { self.seriesMouseLeftButtonDown(evt, ui); }, seriesMouseLeftButtonUp: function(evt, ui) { self.cancelDetailOnDemand(evt); } });
Chris
We are running full Windows 8 Enterprise on a Samsung 700T slate. It was originally running Windows 7. Interestingly the same behaviour as detailed above is seen when running Chrome in Windows 8 desktop mode? This doesn't occur when running Chrome on a PC. And as mentioned iPad works as expected.
And yes, after performing a press and hold it zooms in, which is not the desired behaviour.
Hmmm... I haven't seen that behavior before. I will try to replicate tomorrow. You do a press and hold and it eventually just zooms in?
Is this on Win8 RTM? Windows RT?
