A lot of places mentioned that client-event can be binded anywhere in the application after initialization. However, I have been following different ways that mentioned in the documentation but with no luck. I alrady have the RowSelectors enabled in the feature option at ig.Loader.
Here are some that I have been trying but none of them get fired:
$("#grid1").bind("iggridrowselectorsrowselectorclicked", onRowSelectorClicked);
where the onRowSelectorClicked is a separate function in the same .js file.
OR
$(document).delegate("#grid1", "iggridrowselectorsrowselectorclicked", function (evt, ui) {...});
$("#grid1").live("#iggridrowselectorsrowselectorclicked" , function (evt, ui) {...});
Thanks helping in advance.
if you use live / delegate / on, it shouldn't matter where you put the event binding logic. If you use bind(), it does matter. In order to answer your question, i need to have a look at the rest of the code which initializes the grid, as well as how the event binding logic is placed relative to the initialization code. I just tried some of the events using delegate/live, and it seems to work fine.
Angel
