405
How to get row data from the data view when you have the DOM tr element
Using a js library jsPlumb which establishes connections between grid tr elements. I get a list of connections and from those I can get the tr element at each end of the connection (think of two grids in a work area with a connection between them that indicated the relationship).
The igGrid is created with three columns but only one column is ever displayed at a time (the user can choose to show any of the columns but only one). The first column is the data I need. So if its the column displayed I can get the data easy enough as it is just in the td. That is I just do a,
var trElement = connection.endpoints[0].getElement(); // returns the DOM tr element
alert("trElement.find("td").html()"); // displays the text for the currently displayed column
However, the user may have one of the other two columns displayed instead, so I need to get the data for the cell in the first column that is now hidden. I tried the following:
trElement.attr("data-id");
But that is undefined. If I have the DOM tr element. How can I get the row data?
Pat
  • 23953
    Verified Answer
    Hi Pat,
    The best way to accomplish this is to set primaryKey on the grid and then use igGrid.findRecordByKey method.
    The "data-id" attribute will be available only if you set primaryKey on the grid. I guess you didn't set it. That's why it is undefined in your case.
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
