210
igCombo Within igGrid Row Edit Template displays Empty Text
Hi. I am testing IgniteUI 2012.2's igGrid in RowEditTemplate update mode within MVC/Razor. I noticed that when I am in "row" mode, the igCombo displays the value from the cell properly. However, when utilizing the RowEditTemplate mode, the value in the igCombo is blank. Is there anything special that need to be done to display the value that should be passed from the grid row to the R.E.T? I am just pulling a country list from a ViewData to populate the combobox. Nothing fancy is going on within the project.
Here are my js script calls:
	<script src="~/Scripts/modernizr-1.7.min.js" type="text/javascript"></script>
	<script src="~/scripts/jquery.min.js" type="text/javascript"></script>
	<script src="~/scripts/jquery-ui.min.js" type="text/javascript"></script>
	<script src="~/scripts/jquery.tmpl.min.js" type="text/javascript"></script>
	<script src="~/Scripts/js/infragistics.loader.js"></script>
Here is my loader:
	@(Html.Infragistics().Loader()
		.ScriptPath(Url.Content("~/Scripts/js/"))
		.CssPath(Url.Content("~/Content/css/"))
		.Resources("igEditors,igCombo,igValidator,igGrid.Updating")
        //.Theme("Metro")
		.Render()
My Update call for the column is:
				settings.ColumnSetting().ColumnKey("Region").EditorType(ColumnEditorType.Combo).ComboEditorOptions(options =>
                    options.ValidatorOptions(option =>
                        option.KeepFocus(ValidatorKeepFocus.Never);
                        option.BodyAsParent(false);
                        option.Required(true);
                    options
                        .DataSource(ViewData["RegionDS"])
                        .TextKey("name")
                        .ValueKey("id")
                        .AllowCustomValue(false)
                        .Mode(ComboMode.DropDown);
The template pulls up fine if I display as a text field. Can you provide an explanation based on my snippets and/or provide a sample?
