285
Removing an item from an observable array bound to igGrid does not commit.
I have an observable array that is bound to an igGrid.  When removing item from the array the grid does a strike through of the removed item.  I have autocommit set to true so I would expect the grid to actually remove the item from the UI as well.
Digging into this a little further I found that the delete transaction was not committing and remained in the pendingtransactions array.  I tried to manually commit the transaction and rebind the grid to the array.  When making the call to commit I received an exception 'this._super' is undefined in the file infragistics.datasource.knockout.js in the _deleteRow function.  My file version is (12.2.20122.2056)  I have highlighted the line of code that throws the exception below.  Has anyone else eperienced/fixed this issue?
Chad
 _deleteRow: function (d) {
var c = this.settings.primaryKey,
b = this.kods;
b = ko.isObservable(b) ? b() : b;
if (this.settings.responseDataKey && b[this.settings.responseDataKey]) {
b = b[this.settings.responseDataKey]                 }
if (ko.isObservable(b)) {
if (!this._koUpdate) {
b.remove(function (e) {
return (ko.isObservable(e[c]) ? e[c]() : e[c]) === d                         })                     } else
this._koUpdate = false
} else {
this._super(d)
