Is there any way to insert a new series object in the map's series array and specify where in the series I want it? For example if I initially have a map with with a geographicShape type, another geographicShape type and a geographicSymbol type, the symbols (markers) appear on the top layer. Now I want to dynamically insert another geographicShape type but place it "under" the geographicSymbol series item I currently add it via:
$("#map").igMap("option", "series", [{ type: "geographicShape",
This shape will appear over the symbols thus making them invisible. Having to remove all of the map's series objects and then re-adding them in my desired order seems to be a lot of work on the client considering that it has to redraw the shape polygons again.
Hi Chris,
After some research, the ability to insert series object at a specified insertion point has been determined to be a new product idea.
Your reference number for this product idea is #13010042.
I have created a private support case for you for this product idea to send your your product idea details.
Thank you Chris!
Just want to let you know that I am continuing to look into this. I will hae an update for you on this on or before Thursday.
Thanks!
This note is to let you know that I have received your inquiry and will be looking into this issue for you.
I will follow-up with you on this thread on Tuesday.
