What is the syntax to check for an undefined object property in the igGrid. I'm using 12.2.20122.1021 with the IG Template Engine (which doesn't have much documentation).
var MyObj = [ { Name: "Me", Comment: "Exists" }, { Name: "Myself" } ];
For the above example, how would I check that the "comment" property is missing from the second object?
Hi dirq,
The MyObj array is your grid dataSource I assume. In this case the check inside your Comment column template would be as follows:
{{if ${Comment} === undefined}}Do something{{/if}}
or
{{if typeof ${Comment} === 'undefined'}}Do something{{/if}}
Let me know if this helps or if I haven't understood your scenario well enough. I just want to mention that you cannot reference a specific array index inside the template members. Because the templating is designed to either loop through each data member and instantiate the template with it, or loop within nested array members using {{each}}. However it is not designed to directly access an array member like this ${Prop[3].Prop1}.
Here are some good samples for you to look at: http://ko.infragistics.com/products/jquery/templating-engine/
Here is documentation: http://help.infragistics.com/NetAdvantage/jQuery/2012.2/CLR4.0
i am not sure i fully understand the question, but something like this should do:
if (typeof (MyObj[1].Comment) === "undefined") {
// it's missing
Let me know if this helps. Thanks,
Angel
