920
Column moving fails with hidden column
I am using ColumnMoving CTP with 2012.2 (build 2086). I am having problems with a grid that has a hidden column (see error below). This error ONLY occurs when a column is hidden. The error occurs when trying to moving any column in the grid.
Unhandled exception at line 25, column 49087 in /js/modules/infragistics.ui.grid.framework.js
0x800a138f - Microsoft JScript runtime error: Unable to set value of the property '0': object is null or undefined
thanks
  • 5513
    Suggested Answer
    We are aware that the CTP version of Column Moving has some integration issues with other igGrid features. All these will be resolved with the RTM version planned for release with Ignite UI 13.1.
    Thank you for using the Infragistics forums!
    Best regards,
    Stamen Stoychev
