500
Customize column header tooltip
How to set up igGrid column header tooltip? is the solution from post http://ko.infragistics.com/community/forums/p/66202/334681.aspx#334681 the only way?
Michael
  • 5
    Doesn't look like we have a solution yet for this. Here's another approach that I am using:
    function setHeaderTooltips() {
    $.each($(".ui-iggrid th.ui-iggrid-header"), function (indx, header) {
    //get header text as the default tooltip
    var tip = $(header).attr('aria-label');
    switch (tip) {
    case 'C/C Low':
    tip = 'Cash On Cash Low';
    break;
    //... etc. for any custom tooltips
    //set the tooltip
    $(header).attr('title', tip);
  • 17559
    Verified Answer
    Hello Michael,
    Currently we don’t provide a build in tooltips for the headers of the igGrid, therefore I have submitted this as new product idea. Your reference number for it is PI13010108.
    Meanwhile I could suggest you try the approach that Martin has suggested in the mentioned forum thread.
    If you have any issues implementing this on your side please do not hesitate to ask.
  • 5513
    Suggested Answer
    Hello Michael,
    igGrid supports custom tooltips through the Tooltips feature only for data cells. If you would like to display tooltips for header cells the solution presented in the topic you found should do the job.
    Additionally you could fill a feature request through this form. We base our future development almost exclusively on customers' feedback.
    Thank you for using the Infragistics forums!
    Best regards,
    Stamen Stoychev
