Hi! I searched the documentation but I found only "endEdit" method which is used for the whole row. What I want is to end the editing of a cell on clicking a custom cancel button and setting a value to it on clicking a custom confirmation button, how can I achieve this?
hi Georgi,
Here is a link to the documentation: http://help.infragistics.com/jQuery/2012.1/ui.iggridupdating
End row editing.
That's valid in case of row edit mode. In case of cell edit mode, it will be valid for the current cell in edit mode. You don't need to specify it.
regards
Lyubo
Can you please explain or give an example how to use that method "endEdit", is there a parameter for cell, because in the documentation it is just .igGridUpdating("endEdit"); and thus I can not specify which cell exactly to be ended??
Customizing the updating feature will be a hard job. Updating feature might include different editors/validators + commit modes - auto=true|false for the different type of cells data. That combined with your request will create a hard to support scenario.
I'm not sure what kind of editMode are you using - cell, row or rowedittemplate.
There is a method for ending the cell editing. It's the same as for a row - endEdit
Since you want to customize the updating as much as it's possible, my advise is to you for a totally custom editing solution.
Take a look at this post. IMHO you might find it useful.
http://ko.infragistics.com/community/forums/p/76453/386972.aspx
Hope that helps.
Regards
