Hello ,
Does IgniteUI have RTL suport ?
Thanks Amir.
Hello John,
RTL support is in our backlog, but it won't get into the 13.2 release.
Best regards,
Martin PavlovInfragistics, Inc.
Hi Martin,
I see that your response dates February this year. Do you guys have plans to implement / completed the RTL support on the remaining controls?
John
Hi Amir,
Ignite UI has a partial support for RTL.In order to enable RTL support you need to set the dir attribute to rtl on the element on which control is instantiated.Example:<input id="editor" dir="rtl" />
Here is the RTL support list by control:(This list is not official Infragistics data. I've assembled it based on my experience with the controls.)
igGrid - Partial. You can add some CSS in order to make it work for you.igGridPaging - NoigGridSorting - NoigGridFiltering - NoigCombo - YesigEditors - YesigDialog - NoigDatePicker - YesigHtmlEditor - NoigTree - NoigUpload - NoigVideoPlayer - No
Note that the list isn't complete, because I didn't test all the controls.
Hope this helps,Martin PavlovInfragistics, Inc.
