50
TAB control inside of the igDialog - doesn't work
I am trying to make a Dialog/Window appear using igDialog with two tabs - one tab should contain the chart and another - some other information.
First I declare DIVs :
<div id="igDialog1" style="display:none">
<div id="tabs">
<ul>
<li><a href="#tabs-1">Chart</a></li>
<li><a href="#tabs-2">Table</a></li>
</ul>
<div id="tabs-1">
<div id="msg"></div>
<div id="chart"></div>
<div id="legends">
<div id="legend"></div>
<div id="legend2"></div>
</div>
<h3 id="chartTitle">Energy Production by Year</h3>
</div>
<div id="tabs-2">
<p>Morbi tincidunt, dui sit amet facilisis feugiat, odio metus gravida ante, ut pharetra massa metus id nunc. Duis scelerisque molestie turpis. Sed fringilla, massa eget luctus malesuada, metus eros molestie lectus, ut tempus eros massa ut dolor. Aenean aliquet fringilla sem. Suspendisse sed ligula in ligula suscipit aliquam. Praesent in eros vestibulum mi adipiscing adipiscing. Morbi facilisis. Curabitur ornare consequat nunc. Aenean vel metus. Ut posuere viverra nulla. Aliquam erat volutpat. Pellentesque convallis. Maecenas feugiat, tellus pellentesque pretium posuere, felis lorem euismod felis, eu ornare leo nisi vel felis. Mauris consectetur tortor et purus.</p>
</div>
</div>
</div>
Then when needed call:
function initializeDialog()
$.ig.loader(function()
$("#igDialog1").igDialog({
headerText: "Quick view",
width:700,
height:700,
state: "closed",
modal: false,
draggable: true,
resizable: true,
closeOnEscape: true,
$("#tabs").tabs(
collapsable:true
When Dialog shows up - First tab is delighted, but information from from the second tab - is also visible. How do I make it work? My goal is that upon click on the row in the grid (this works nicely) - show Dialog with two tabs - one will contain the chart and another table.
Any idea? Should I forget the IGDialog alltogether for this type of functionality?
Thanks!
  • 50
    Verified Answer
    Unfortunately (or fortunately) I have an answer.
    The problem has to do with jquery-ui version. The proper version for TAB controls is 1.9.2. This means that you have to use current version of jquery supported by Infraghistics (seem to be 1.7.1), but version 1.9.2 of jQuery-ui. Not very cool.
    Besically I have to do this in my code:
    <script src="http://code.jquery.com/jquery-1.7.1.min.js"></script>
    <script src="http://code.jquery.com/ui/1.9.2/jquery-ui.min.js"></script>
    Then everything - TAB and Infragistics controls work fine.
    Any additional input will be appreciated.
