I have a grid that is displaying a date of 1/1/2013 (It was populated from a DateTime object 1/1/2013 5:00 AM in UTC time)
It displays in the grid as 1/1/2013. However when I do the following to get the underlying record for the row and log the columns value to the console it is now incorrect and displays in the console Mon Dec 31 2012 19:00:00 GMT-0500 (Eastern Standard Time)
I use the following calls to get at the record that was used to populate the grid
var grid = patientInfo.data("igGrid");
var records = grid.dataSource.dataView();
var activeRecord = records[index];
What can I do to keep the correct date/time in the grid. I have tried converting all DateTime objects ToUniversalTime and that did not help
HI ,
i am getting in that format at mvc controller or transaction gt/Date(1509954765000)/
even i have done the enableUTCDates :true
thanks,
Siddharth
Hello Ddally,
I have opened a support request(CAS-110970-B0L6H5) for this forum post so we may research this behavior further. Please use the following link to log onto your account at Infragistics.Com:
https://ko.infragistics.com/my-account/support-activity
Once you are logged onto your account, go to My Support Activity to view the progress of this support request. An update will be sent to you in the support request with any new information we find.
Looks like for null dates it is adding
It does spit out a date, it just spits out an invalid formatted date according the the javascript deserializer
Nevermind, it looks like the formatter will spit out a valid date
