Is there a way to animate the chart series when the chart is loaded? I'm trying to achieve something similar to this animation http://www.highcharts.com/
Hi, there are ways to achieve an initial animation in application code. Basically you can set a transitionDuration on the series and start the data at 0. Flush, or let the chart initially display and then change the data to have the actual values you desire.
See this example for a strategy:
http://jsfiddle.net/vbNLx/3/light/
Hello chaitanyavrk ,
I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
There’s no such option out of the box.
However if you use the motion framework of the chart and add the data points one by one you might be able to achieve a similar effect.
For example refer to the following example:
http://ko.infragistics.com/products/jquery/sample/chart/motion-framework-with-column-series
The adding of the new series is animated. You could on load of the chart add the items elements one by one using the notifyInsertItem method .
Let me know if you have any questions or concerns.
Developer Support Engineer II
