TypeError: c[parseInt(...)] is undefined @ infragistics.ui.tree.js:29
I get this when I click on a node via
nodeClick: function(evt, ui) { alert( ui.node); }
this is my tree
var data = { "Text": "dataX", "Value": "dataX", "dataread": inData } //init code. $.ig.loader( function () { inIUDiv.igTree( { checkboxMode: "triState",//biState singleBranchExpand: false, dataSourceType: 'json', dataSource: data, bindings: { textKey: 'Text', valueKey: 'Value', childDataProperty: 'dataread', bindings: { textKey: 'Category', valueKey: 'AdvantageName' } }, nodeClick: function(evt, ui) { alert( ui.node); } } ); } );
also I can not check boxes under the root and if I check the root box I can not unchecked it or any items that were checked from it?
was a result of bad data. Working now.
